heating - gas or electric
Gas. Should you ever have a power outage, a small generator is your friend and you can still cook and bake without power.
Originally Posted By: Jarlaxle
Originally Posted By: tig1
I have electric baseboard heat on 3 circuits. Very easy on the budget, clean, no drafts, quite, doesn't dry out the house compared to gas, cheap to do repairs, rooms that aren't being used can easily be shout off and not heated as each room has it's own thermostat. I thank that covers it. Oh! No gas monthly minimum charges which is $20 a month here. Lets see. 12x20= $240 a year savings.
And how much is your electric bill again?
Electric heat (resistance heaters, not heat pumps) is usually VERY expensive. When my mother replaced her water heater with tankless propane, her electric bill dropped by more than half in the winter!
Last months bill was $151. We are all electric so I don't pay the $240 a year hook up fee for the right to have gas. Plus I get all the benifits of this form of heat. Far more comfortable than forced air gas.
Another option some new construction is using is geothermal with a heat pump. It's an expensive initial outlay, but it can work well, especially if you don't have the option of municipal gas & live where it gets cold.
