My '89 Mopar LA 318 TBI has a heat riser valve on the passenger side manifold. When cold it directs exhaust gases through the intake manifold to the drivers side exhaust manifold to warm up the intake and base of the throttle body. I know these frequently clog up, but mine was not 15k miles ago, and the last time I removed the EGR valve I did not see butt loads of carbon.
Mine has been inoperable for years, and since I live in a warm environment, I just tied it open and forgot about it.
Now it has started to leak exhaust gases around the Pivot pin.
My single 02 sensor is in the driver's side manifold.
I'm wondering if this leaking heat riser valve could be sucking in air from the manifold, and somehow making it across the intake manifold to the 02 sensor, making the 02 sensor send a lean reading to the ECM which then enrichens the mixture.
My engine is running slightly rich, especially when cold, when the heat riser valve is leakiest and makes the most noise.
I have resorted to tin foil and hose clamps on the pivot pin to temporarily quieten the noise. My butt dyno tells me that this makes the engine run better, but the cynic in me does not believe my butt.
I fear removal of the exhaust manifold will result in broken bolts and/or studs in the head and do not wish to open that can of worms.
I'm leaning toward removing/ dropping the Y pipe, cutting the pivot pin in half from below, complete removal of pin and butterfly, and inserting some NPT plugs into the pivot pin's holes in the cast Iron manifold.
What say you all.
What say you all.
