Have to eat crow
Originally Posted By: circuitsmith
Originally Posted By: dnewton3
However, the LOCATION of the filter (side of the block, under the block, high above the block) will alter the attempt of oil to drain back. This may or may not make an ADBV moot.
With the filter mounted high there is still gravitational effect in the passage leading down from the filter to the pump/sump.
So maybe ADBV is still needed even with the filter high.
I disagree, but I'll explain why.
First, think of how a "normal" filter application sits and performs: traditionally the filter is low on the block and the ADBV is a check-valve of sorts. It stops flow from escaping the filter in the reverse direction. Once shut down, gravity will force the fluid to put pressure into the center tube, thereby trying to push through the media, and stops at the ADBV (generally, as this is it's purpose in life). The check-valve effect holds the oil in the circuit because it is stopping the lube from wanting to leave the filter through the outer hole in the baseplate. In short, the ADBV stops oil from reversing its direction through the filter.
In a high placement situation, typically the filter is inverted and the baseplate is lower point (think 4.0L V-6 Tacoma with dome end up). The filter is very high relative to the engine; at or near the head level. There is very little pressure from the "system" that exists on the upstream side as the pump is shut down. The pressure-fed side of the filter in normal ops is the outer ring of inlet holes, and feeds lube through the media and into the engine via the center tube. Once the engine stops, the pressure feeding into the outer holes stops, but ... there is nothing to stop the oil from continuing to drain through the media, and through the center tube. The ADBV is "upstream" in this sense, and there is nothing in the filter to stop oil from draining in its "normal" direction. Because the pull of gravity is acting on oil in the "normal" direction, the ADBV cannot stop this from happening. Now - it is entirely possible that some other check-valve exists in the engine itself, downstream of the filter to stop this; something could be in place with a low pressure holding point that would stop drain-down with no pump pressure, but was easily overcome with just a few PSI? I have no idea if this exists in the system, but conceptually it could. However, it is not the FILTER ADBV that would be achieving this. In the high-placement, inverted orientation, the ADBV does little-to-nothing because the oil is draining in its "normal" direction and not against the ADBV.
It is possible that in a high-placement, base-plate-up orientation, the filter could hold some oil, but that would be simply because the filter is a "cup" of sorts, and regardless of the ADBV presence, some oil would stay in the "can" with graviting pulling it towards the dome end. However, this is not a typical mounting scenario in most engine apps.
ADBVs don't do much, if anything, when the filter is high, dome end up, because the ADBV is not affecting the "normal" flow direction of lube. It generally will only stop reverse flow.
If you see it differently, please explain.
Originally Posted By: CapitalTruck
...That's correct. At some point GM made the switch from the bypass-in-block to bypass-in-filter. I can't remember when it was, but it would be indicated by determining when they switched from the PF46 to the PF48 for the LS series V8 in this truck.
Yes as stated, newer GM vehicles no longer use block bypass thus the need for a filter integral bypass. Son's 2011 Tahoe specs a filter bypass.
Just speculating here, but it's also imo why GM had to decide if they were going to continue using the ecore designed filters if they were going to use the nitrile combo valve. As the new ecore design shows, the nitrile combo valve was a no go. GM decided if we go ecore then we are uing a traditional separate metal coil around nylon poppet bypass valve. That should tell you something about what GM thinks about the nitrile combo valve design.
As for the discussion regarding whether an adbv is needed and/or useful if the filter is mounted at the top of the engine thread/base end down, I believe it is. If the vehicle manufacturer specs one, I believe they do so for a reason.
That and I have a few links* to the specific topic and included the mentioned Tacoma 4.0L with filter mounted at the top, which by the way specs an adbv. There is also a good discussion of using a standpipe in the filter also designed to hold oil in those type applications. The late Gary Allan (rip) contributes to the discussion as does river_rat on the standpipe applications and filters mounted dome end up at an upper or top of engine application. I'll leave others to debate by if owned a Tacoma or other vehicle with filter in that orientation I would want a filter with an adbv at least. Enjoy the reading, it's informative imo.
As an aside the PH9837 is one of the rare applications that doesn't spec an adbv, and it's used on GM products which I assume are in a thread end up orientation.
ADBV, standpipe, running a big filter inverted etc
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1959394#Post1959394
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1697070&page=1
Just to be clear, my application is thread up. Reference the adbv/bypass combo, does Champion use that system in their ecores? (with the exception of ACDelco)? I ordered a couple of "Champ" PH48 e-core filters, they should be arriving tomorrow. I am going to cut those open to do a comparison with the ACDelco e-core PF-48 filter.
^^^^^No idea if Champ uses combo valve in non ACDelco ecore apps meant for GM. Really shouldn't even need to cut one open to find out though. Don't see a separate dome bypass down the center tube and the Champ PH48 is spec'd for said GM, then yes it is using a combo valve. But the new ACD PF48E doesn't use a combo valve, as noted previously.
And I understood that your application is thread end up, however the had discussion veered to an opposite orientation.
Originally Posted By: Donald
Return them to Walmart.
Certainly the OP could return the filters there that he bought from Walmart.
Then he could get you to give him a refund for the rest.
