Quote:
Seal swelling agents will not fix the seal but they might buy you some time. The seal is leaking becuase it is one of the following: hard,dirty,dry rotted,cracked,worn or shrunk!!! Now the additional seal swelling agents in a bottle of max life are no better for the seal then a bottle of stop leak. What willhappen is if the seal is made from a material that is suceptable to seal swelling compounds it will swell. The problem is that the swelling is not a controlled process and if it swells too much it will accelearte how fast an already worn seal wear's out. It will not repair a cracked,dry rotted or dirty seal. I would buy a $5 bottle of some type of engine stop leak. If it works it will not matter what brand of oil you have in their. It will also tell you wether ornot pursueing oils's with sever so slightly higher amounts ofd seal swellers might be worth while. You can add the engine oil stop leak right to the exsisting oil. CD2,TransX,Bardell,Gunk etc..... all make and market some type of engine stop leak. Stay away from the stop leak no smoke combination products.
