May not be the problem, but sometimes the rubber above the firewall that contacts the back underside of the hood wears or has one or more cracks in it, allowing rain water to get to the engine. Sometimes water finds it way to some of the sparkplugs and the sparkplug insulator and boot end up sitting in the rain water. The other plugs without this problem will still fire good, and when the engine gets hot enough the water boils off and or falls off as the vehicle accelerates, brakes, goes around bends, goes up and down hills.
So if the vehicle has rubber that contacts the back underside of the hood check it.
Another one (probably not your problem), some vehicles have a flexible rubber or some other water guard by the upper A frame gets moved when someone works on the vehicle, so that when the vehicle hits a puddle or water in a pothole water can splash onto the ignition wires.
