Car: 1999 Nissan Maxima, Front wheel drive, Automatic, Non-ABS, 4 wheel disc brakes, 146k miles on the odometer.
I recently noticed a grinding noise during heavier braking from speeds of about 35 mph to 0 mph.
At first I thought that my front brake pads may be due for a replacement since it has been about 43k miles since I last replaced them.
After taking the wheels off and inspecting the front brake pads, I noticed that there is still some meat left and they should not be causing the problem.
After raising the rear end, while the cars parking brake was applied, I noticed my driver side rear wheel spinning freely.
Does the parking brake hold both rear wheels or one wheel on a front wheel drive car?
The driver side rear wheel also has a little bit more brake dust than my passenger side rear wheel which remains locked when I apply the parking brake.
I wonder if the grinding noise under braking has anything to do with my rear driver side wheel spinning freely with the parking brake applied?
I also noticed that the braking power to fully stop the car is a bit weaker than usual under heavier braking. Maybe it's my imagination since I'm hearing the grinding noise and I'm picking.
Both rear calipers were replaced along with new rear brake pads and rotors about 22k miles ago.
