Ray, in a lot of cars I'd agree with you. But the owners manual & FSM both specify 7 qts for AC equipped Neons. Refilling has required about 5 qts poured into the thermostat housing, plus another quart or so into the overflow tank. My capacity may be down a little now becuse the new radiator has the tubing on bottom for an automatic transmission.
Still, it's a good point. Maybe I'll get my local service station to check with their hydrometer(should be much more accurate than my old cheap pocket antique!) and work out just what my percentage is.
And since I plan to change the timing belt, idler pulleys, & water pump in a few weeks, I'll have an opportunity to add a little more straight antifreeze if it should need it to come up to 50%.
