I'm not the foremost expert when it comes to this...
When putting a sealed bearing back into a bearing cup of some sorts....(in my case it's auger shafts that fit on the chassis, or a drive pulley/impeller bearing), do you put the bearing onto the bearing cup dry, just crease the metal faces, and or is it okay to wipe a light coat of grease on the faces/shield of the bearing itself. Assuming grease attracts grit/dirt (the synthetic Superlube grease I use) tends to not attract dirt/dust as much in my experience. I don't think there is a possibility that the product may SEEP past the seal, but what about antiseize ?
For example, on 1 shaft, if I was to use marinegrade antiseizem when I slide the impeller onto the shaft, it does somewhat *push the antisieze* down the ends of the shaft....which the bearing is at.
Thoughts.
Do I keep these bearings as dry/greaseless as possible, a light coat of grease all around is a good idea, or just a dab on the metal shell.
Thoughts.
