Grease Points on 2006 F-350
Baltimore
Hi all. I am now changing my own oil and I looked for the grease nipples on the chassis and wheel bearings etc on my truck (2006, F-350 regular cab 4X4 SRW) and I couldn't see any. It was getting dark out so I am assuming I just missed them.
Before I go crawling under there again, does anyone know where to look specifically? The owner's manual states a lubrication spec for the spindle bearing so I know there should be at least one for these.
Any help would be greatly appreciated.
Jamie
i think they are just one on each outer tie rod. might be one on the pitman arm. bearings are sealed and very expensive to replace if they have any grease introduced to them.
A lot of new Light Duty Fords are now sealed. Some as recent as 05 still had grease fitting everywhere but recently seeing them come in with NONE!
Did not see them then it is probably a new sealed chassis design.
