Grease for polymer/metal gear system
JHZR2
Staff member
New Jersey
Hello,
rebuilding a 27yo hirschmann power antenna from a mb, because the shaft was bent and the new one wasn't taking.
Gears are some polymer (nylon perhaps, but no guarantee) mating to a metal worm gear off a motor.
There is a decent light tan grease on various parts, but it is blackish where the gear and metal meet. No notable wear on anything, issue with operation was bent shaft caused the shearing of the shaft leader, putting lots of debris inside.
Grease was fluid and decent after 27 yes. Would like ideas of the best grease.
Old stuff reminded me of lo-temp Mystik grease sold at tsc, but I doubt petroleum was used in there.
Any recommendations?
Thanks!
A little late, but if anyone else is interested this looks like an interesting grease for similar applications.
I'm considering it for bike bottom bracket bearings which usually aren't sealed that well and I want a low drag grease.
http://www.anglomoil.com/tds/RoboticGrease.pdf
An NLGI 00, Calcium Sulfonate thickened (better corrosion/water resistance than a lithium or aluminium thickened grease) semi-synthetic oil (have no idea what type) with PTFE.
