Hey, how's everyone's Saturday going?
I have a 96' Dodge Grand Caravan ES 3.8L and I want to bleed the brakes. These van's are notorious for [censored] brakes, failing transmissions (i'm on the 4th one), and other stupid stuff like electrical gremlins which make the wipers go on and off at random times.
I'm thinking about doing a gravity bleed. I don't think the brake fluid has ever been changed and the van now has 224k miles on it. It's mainly used as a part's hauler, or other work in which I don't want to get my DD dirty.
Any recommendations on what brake fluid to get?
Also, do I need a clear tube for the brake bleeder screw, If all I'm doing a gravity bleed? If so, what size clear tube?
Here's how I plan on doing it, please correct me If I'm wrong. (btw: I'm not draining the rear brakes).
1. Open brake fluid cap under hood.
2. Open brake bleeder screw on passenger side front caliper.
3. Let fluid bleed for 5 minutes.
4. Monitor brake fluid level while bleeding.
5. Close brake bleeder screw, when I see new fluid coming out.
6. Repeat process for driver side front caliper.
