I felt that I needed a 2nd one in case my older one failed for some reason. Being in Ca I can no longer run to a store and buy a gas powered one and I don't feel that a battery powered one is sufficient to do what I need. Maybe I'm wrong but anyway.
I ordered anothe Echo SRM 225 straight shaft one just like my old one. It showed up today.
I had some tru-fuel 40:1 fuel so I used that. I feel that a little extra oil is better with a new engine even if it will effect the air to fuel mixture slightly.
Thing calls for 50:1. I will go to that after I burn through this tank of fuel.
I immediatley noticed that the new one runs much smoother than the old one. The old one has a Koritz engine. The new one has a name I can't remember right now. Looks the same anyway.
The plastic housing around the engine gets very hot. The old one does not. Maybe they deleted some insulation?
I had to adjust the idle as the new one would die if left running. Set it down and it would die in about 3 seconds.
Idles now.
The handle in the center is flexable where the old one is more rigid. This may account for a lot of the vibration I get from the old one.
While they both wear me out I was able to wack over an hour this morning and don't feel beat up.
The muffler on the new one is much louder than the old one.
So far I'm happy with it. Dunno why I had to adjust the idle speed though. Seems ok now.
Idles now.
