Good plug and play router?
I think if you don't want to deal with it, the most important thing is the range and throughput. In such case assume you have a big house and you want speed all over, then a router with multiple bands (those that support 2.4GHz, 5GHz, and 6GHz, and 3+ antennas) would be ideal. This is likely in the Wifi 6e or Wifi 7 class.
If you have money to spare do a speed test from every part of your home and see if you have spots where reception is bad, and can add a mesh extender. So, I guess you should buy a router that support mesh to start with and add a mesh extender here and there as needed.
I like many different brands, I use TP Link mostly because they are cheap but if you want a Taiwan or US brand then TP Link is not one.
Does either the Asus or Unifi come with a firewall? Or is that old news and replaced with something better?
Yes, the Unifi router has a very configurable firewall, IDS, IPS and content filtering. Here's a shot from my UDM:
Hi guys, I am now in the market for a new router - I'd like to keep the cost to less than $200 if possible and don't really want to have to use my phone and an app to configure the silly thing and I'll admit that I've fallen behind the times and am no longer familiar with the features that modern router should have.
I was looking on the Jungle Site and found some Cisco routers but many of them are "integrated services" - is that a router that also acts as a modem? I had seen some recommendations here in old threads to get a Netgear Nighthawk, but after having read the reviews on one model, it looked like it was difficult to set up (app) and flaky, which makes me want to steer clear of them.
TP Link. I has an app option but I used the step-by-step online setup and it was easy and fast, plus has easy software updates.
Something from UniFi. Very modern, very solid, and no need for an app or an account (but you can use them if you want).
https://store.ui.com/us/en/category/cloud-gateways-wifi-integrated
I have an older Dream Router (per recommendations given here) and it's like something out of Star Trek compared to the D-Link I was using. You need to be fairly savvy to set it up to your liking but after that you're golden.
do any of the discussed routers work with Verizon Fios wo alot of special setup requirements to do so? Seems they want you to use their router to generate usage fees
Any router will work with any ISP. The modem is the bit between the router and internet that is specific, basically you can’t use my DOCSIS 3.1 modem, but you could take my router and use that. You’ll just want to disable the WiFi if you have a modem/router combo unit.
Well I ended up ordering the Express 7 - I liked the idea of no apps and hopefully simpler set up better.
Is there any benefit to upgrading my Ethernet cable to the router? I have a flat style CAT6 right now. Also is there a benefit to running the TV off of a cable instead of WIFI?
express 7(UX7) is a good pick..-very much upgraded over the express(ux-us)
the new express 7 comes with wifi7, and ids/ips etc. The first express had a Dorito for a processor chip so you couldn't run ids ips.
If you need extra range you can add another Wireless access point with mesh or Ethernet.
Do you have a switch to use with it?(or need one?)
The main possible downside of the express is it has 1 lan port.(for your local wired network)
It is one reason why the CGU(cloud gateway ultra) or Dream Router 7 are sometimes more appropriate.
If you have any questions feel free to DM me.. or Tag me in @Rand
Not a pro but fairly familiar with this brand.
I may well take you up on that offer, thank you very much!
Sept/Oct issue of Consumer Reports tested OVER 60 routers for anyone interested.
Top honors in the non mesh category goes to a surprisingly inexpensive ASUS TUF-AX4200 with a score of 92
Next is Synology RT6600ax with a score of 91
Pretty much ASUS is in the top ten 4 times, Synology 2 times. With that said most routers did well and hard to find a bad one but you pick and choose what is important to you. It does make me want to go shopping and look for a Asus deal in the top ten, who knows.
With that said except for the very top, the scores among all devices are pretty close in the 80s out of 100.
Currently happy with my TP link AC 4000 tri-band even still I can get download speeds at the limit of my service over WiFi on my cell phone of 500 mbps about 15% less on some other devices... but it is older now... so an ASUS with the right rating for WiFi distance might be appealing at the right price.
Im shocked how many ASUS are near the top (and the lower prices) but would look at individual publications with the model numbers from there to see if they match what I need. I typically buy units about to go out of production, ill do nothing unless something compelling comes along but it may help someone else.
