Good Explanation on Alignment Procedures
CA
I was doing a search for some alignment info tonight and came across some posts written by an engineer who used to work for Hunter Engineering. He is very knowledgeable about alignment equipment and I found his explanations about adjusting front toe, rear toe, steering wheel centering, and CAMM adjustments to be quite helpful and understandable.
http://www.tundrasolutions.com/forums/616988-post8/
http://www.tundrasolutions.com/forums/suspension-and-axle/59108-dj-follow-up-on-alignment/
Hopefully some of you may find the info or explanations helpful as well. The Hunter wintoe feature which allows for steering wheel centering without a steering wheel holder is interesting as well.
On my car a spreader bar is necessary to get everything right, and most techs are too lazy/unknowledgable to do it right...
