Good door hinge grease/spray?
PA
What do you guys like to use for door hinges, hood latches, etc.
Are there some types that covers multiple applications? Dry lubes? White Lithium?
I am old school and use a gravity style old click bottom long snout oil can. It has a mix of bottom of the jug motor oil. Works for me.
Think that's the only lube that stinks worse than MaxLife !
Probably 4 cans of it on my shelf … great for misc things …
I use Door Ease stick lubricant for indoor hinges. It is available at the local hardware store. I get 10-15 years of squeak free service from this.
I have some leftover Liqui-Moly MoS2 - that stuff is AWESOME. Penetrates well and then leaves a dry moly on there
so ONE application, and forever done!
Its also great for a penetrating oil on screw nuts and bolts in very high heat application.
And its cheap.
I have used P B Blaster with success , but it eventually went away / evaporated . I am guessing engine oil would stay some what longer ?
Quote
I like this idea the best. There is also a spray chain/cable lube that works the same way.
LPS #3 is also an option. It's more of a spray grease, but is claimed to last 2 years.
Originally Posted by diyjake
Originally Posted by Lubener
I use a couple different Blaster products. I won't use oil or lithium grease that will do nothing but attract dirt and grit which will grind the hinge to death.
https://blastercorp.com/blaster-corp-products/
Which one do you use for hinges / latches?
I use the garage door lubricant.
