leaving the engine in neutral or in gear still use fuel, how much it uses depends on the vacuum, rpm, and the emission output.
From what I see in uberdata's forum, engine control takes those parameters into consideration. If you leave it in neutral it uses gas, but less than in gear because the rpm is lower. However, leaving it in neutral is dangerous and can wear your transmission out quicker when you put it back in gear or if you need the power in emergency, you are risking the life of yourself and others by saving say, 0.2mpg during that short period of time. Not a wise move.
Plus, leaving it in gear provide some (not alot) engine braking thus your car won't be as fast.
A transmission is more expensive than brake, and brake is more expensive than fuel. Life of anybody is more expensive than all the above sum up. Remember that.
