Originally Posted By: ArrestMeRedZ
'96 was the first year Dexcool was used in the trucks, and there were major problems with lower intake manifold gaskets and coolant leaks. Bad gaskets that were incompatible with Dexcool. I wouldn't risk it with earlier year gaskets. I would flush it well, and not use Dex or a Dex clone. Hopefully no damage has been done. If you want to use a long life coolant, I'd recommend Zerex G-05, which is what I use in my '97 5.7 truck (that had bad LIM gaskets caused by Dexcool).
Quite a few 1995 truck models were born with Dexcool, The LIM gasket on '96-'02 Vortec engines are a flawed design, While OAT coolant didn't help the situation......It sure wasn't THE cause.
Running conventional green coolant didn't make the original design gaskets last any longer. Plastic carrier gaskets with thin beads of silicone between dissimilar metals, Throw in a few thousand head cycles.....Equals failure!
The LSx based truck engine have failure prone gaskets of the same design & don't come in contact with Dexcool.
A 1995 TBI engine will have steel core composite intake manifold gaskets.
Dexcool is a excellent coolant!!
