2012 Yukon XL 1500 I have new bearings and axles as of last year, OE GM bearings and new Yukon axles from East Coast. Having a wheel balance issue and it could be the balance but I did lift the wheels today and I cannot feel any up and down movement, but if I grab the tire and 9 and 3, I can move the wheel enough to see it move. To clarify, if you were facing the LR wheel, the 9 o'clock would move into the car, and the 3 o'clock would move towards you, and vice-versa. The RH side is barely noticeable, but the LH is visible. Would this be normal allowable movement?
