- Joined
- Oct 21, 2021
- Messages
- 4
I have a 2018 Chevy Silverado 1500 4x4 (5.3L V8, 8 speed transmission) with 76k on the odometer. No drive train fluids have ever been changed. I would like to replace the front diff, rear diff, transfer case, and transmission fluid. Looking at the owner's manual, here is what they recommend:
Automatic Transmission (8-Speed Transmission) = DEXRON-HP Automatic Transmission Fluid (GM Part No. 19331925)
Front Axle (Four-Wheel Drive) = SAE 75W-90 Synthetic Axle Lubricant (GM Part No. 88900401)
Rear Axle (1500 Series) = SAE 75W-85 Synthetic Axle Lubricant (GM Part No. 19300457)
Transfer Case (Four-Wheel Drive) = DEXRON-VI Automatic Transmission Fluid
Question: Are the GM fluids perfectly fine to run or are there offerings from a different manufacturer that are significantly better than GM's fluids?
