GM EOC/TOC disconnect tool
I can't tell you a part number but can verify that such a tool exists. The one I have is a pain to use. Maybe other designs work better.
I've found that a simple right angle pick works very well and is what I actually use. The pick can just pull the clip right out of the fitting allowing the line to slide out.
I concur with yonyon. A right angle pick, two angle pick (not to be confused with the multi curve pick) or a small screwdriver will suffice.
