M m2200b Joined Aug 28, 2005 Messages 1,574 Location Alamo, CA Mar 1, 2006 #1 I know you crush them, that I add about 1-2 oz per qt but where / how do I add them? As dilluted in a pint and add to reservoir? Or radiator fill cap when cold?
G George7941 Joined May 10, 2005 Messages 3,028 Location Toronto, Canada Mar 1, 2006 #2 Add thru rad cap directly into rad, much better than adding to reservoir. That is the way I have done it for years.
T Turbozombie Joined Apr 7, 2005 Messages 19 Location Calgary, Canada Mar 9, 2006 #3 What are some issues with adding more tablets than what is recommended?
G George7941 Joined May 10, 2005 Messages 3,028 Location Toronto, Canada Mar 9, 2006 #4 I am guessing that too much will plug up the rad and heater core passages.
E edwardh1 Joined Jan 17, 2003 Messages 3,462 Location Coastal South Carolina Mar 23, 2006 #5 do Japanese engine makers use coolant tablets?
M m2200b Thread starter Joined Aug 28, 2005 Messages 1,574 Location Alamo, CA Mar 24, 2006 #6 Not new or when you change japanese engine's coolant. It would be one solution if leaks develop and you're sure its the radiator.
D Drew99GT Joined Oct 11, 2002 Messages 22,216 Location Colorado Springs Mar 25, 2006 #7 I've heard that Subaru has started adding stop leak from the factory.
P pbm Joined Apr 19, 2004 Messages 10,631 Location New York Mar 26, 2006 #8 Are these coolant tabs the same thing as Barsleaks?
M m2200b Thread starter Joined Aug 28, 2005 Messages 1,574 Location Alamo, CA Mar 26, 2006 #9 Same as Barsleak in the little round tube.
