GM 4.3 Valve Cover Gaskets
Pittsburgh, PA
Tomorrow's New Year's Day project since I'm off work will be new valve cover gaskets on the ex-phone co. '87 Astro work beater. I got new gaskets on the way home from work, parts guy at NAPA asks "Cork or rubber?", I choose rubber since I've heard they don't need sealant but the NAPA guy says I can put a thin bead on anyway. I have tubes of Permatex 1 and Permatex 2. Which would be better, or does it matter? Or do I not need any at all?
Thanks and Happy New Year!
I use Mr. gasket ultraseal valve cover gaskets, and I highly recommend them. No sealant needed, and they are a silicone impregnated cork. The rubber over metal frame gaskets are very good and reusable. No sealant is needed with those either.
As best as I can tell, these are Victo-Tech gaskets from Victor/Dana. There are three different gasket descriptions on the package I suppose to use the same package for different gaskets. No bolt holes so I guess I have the center-bolt covers. I've owned it a little over a year and never had to take the engine cover off yet. Thanks.
victor reinz makes good gaskets. I would use them without sealant first. If you have a leak, then use a thin coat of rtv on each side of gasket.(whatever RTV you care to use). Centerbolt valve covers have been used since 87 IIRC.
All done, thanks. The gaskets on it were rubber too. They seemed in good shape actually. Tops of the covers were real cruddy though, I think stuff is getting by the assorted tubes and all plugged into them. Insides pretty dirty too, I cleaned them out as best I could but nothing short of sandblasting is going to clean them I think. We'll see if things dry out some. Lost my star bit and extension adapter on the very first bolt, it fell down by the engine mount and I can't find it.
Fortunately I got another set for Christmas.
