The GL ratings are for gear oil. They usually indicate the amount of extreme pressure additives contained within the oil. It is not a rating of quality or an ability to conform to any specs like the API SM rating. The use of a gear oil with a GL rating over GL-4 in a manual transmission containing yellow metals may cause corrosion at high temperatures.
