- Joined
- Jun 2, 2003
- Messages
- 23,587
LETTER TO MOBIL
I have noticed that Specialty Forumlations offers GL-4 lube. So it's not an obsolete spec?
What's the deal? Is GL-5 safe to use if GL-4 is specified, or isn't it?
[ January 06, 2005, 07:22 PM: Message edited by: moribundman ]
MOBIL REPLYquote:
Current Customer:yes
Question:I need technical info regarding the potential long/short term negative effects, if any, of using MT1 GL-5 transmission oil in a manual transmission that specifies a GL-4 oil be used.
Thank you,
-XXXXXX
I remember being told "modern GL-5" lubes did not lead to yellow metal corossion. I've also heard yellow metal corrosion was only an issue at high gear lube temperatures that will not occur in a street-driven car.quote:
The GL-5 lubricant has high levels of EP additives which is sulfur and will erode yellow parts found in many transmission such as brass and bronze parts. Therefore Mobil does not recommend our product be used in any transmission using yellow metals under any circumstances.>>
