First post here so "Howdy!".
Located in south Alabama After years of "we need to get a generator"...we're finally getting a generator. We will be getting a Champion 7850/6250 dual-fuel generator in a couple of weeks...on order, slow boat. Anyhow, I've got some questions/thoughts that I'd appreciate some feedback on...so I'll know I'm on the right track.
Calculating a 20% running overhead and including a 1200w surge for a side-by-side refrigerator the generator will be running and handling surges at roughly 50% load.
The generator will be used for emergency power outages and *maybe* for remote building projects. Living where we do we are not immune to hurricanes and can have power outages for a few hours to a couple of days. The "days" long outages are not very frequent, thank goodness, but...you never know. The longest we've been out is five days back after Opal came through. So, the generator won't be ran that often for extended times but when I want it to work, I want it to work.
I've already figured out (from reading here on the forum) to swap out the Torch plug for a NGK. Weird thing about that is that the specs state it comes with a Torch but the recommendation is for the NGK. Seems Champion would have already swapped them out. Anyhow...on to the questions.
Oil? Recommended is 10W30. I was thinking of Mobil 1 10W30 Synthetic. I run it in my '03 Jeep and have just switched from the extended mileage version to the high-mileage version at 107,400 miles. I do want an oil that will give the generator it's best protection when it's used. It seems to make sense to use what I normally keep on hand and that looks like that will now be Mobil 1 10W30 Synthetic High Mileage. Should I look for a different oil? I'm game for stocking some specifically for the generator if it will serve the generator better.
I've tossed it back and forth between going with an interlock and receptacle or going with a Reliance 6-circuit transfer switch. I think either one is safe but it seems like a lot of wear-and-tear on breakers in the main breaker box in turning them on and off each time you or and shut-off the generator. I'm pretty much sold on the transfer switch. Any thoughts on going this route, installation suggestions or whatever is appreciated.
I sent our propane company a query on getting a connection for the generator installed. Just emailed them today so it'll be next week before I hear from them. We have a 500 gallon tank that we use. I believe I will need to replace the regulator on the tank in order to run the generator. Then, on the house-side of where I tee off for the generator line the old, lower pressure regulator can be installed to serve the house. That sound about right?
I'm still trying to figure out how I'm going to shelter it during rainy conditions. I'm thinking of a very small lean-to shed with a short wall. Just something to keep direct rain off of it when it's running...maybe go with three full walls to block rain from the prevailing direction that our storms come from. Still tossing ideas around.
Anyhow, any info you feel like sharing about this project I'd appreciate!
Thanks,
Ed
