Hello All!
Recent generator purchaser here and have a couple of questions on storage. I picked up a Harbor Freight 5.5kw unit as our power has been pretty wonky around here lately and with a finished basement we need to keep the sump running no matter what. Working in IT, I know generator tests are needed (ours at work is automatic) to ensure they work when you need them most.
So I'm wondering if my storage regimen makes sense. The plan is to run it every month for an hour with either a 500w shop light and/or space heater for about an hour while I cut the grass. This way the neighbors won't object.
I've got 10 gallons of gas treated with StaBil that I will rotate through the cars every 6 months or so (cans are dated) and I've got the generator's gas tank 1/2 - 3/4 full with treated gas. I figure this will give me about 15 gallons of gas and about a day of runtime before I need to look for gas.
For shutdown, I just shut the unit off, didn't flip the fuel cutoff and run it dry. I figure with the monthly runs this is not needed as I'll run the tank dry and then fill up with fresh treated gas.
Plugs will get changed yearly when I do the lawn mower, weed whacker, etc. Oil will get changed at least once a year or 50 hours which ever comes first. After this next oil change, I'll probably switch to Synthetic (unit only has 4-5 hours on it now).
Does this make sense? Is it the best way to keep the unit running in tip top shape?
Thanks for any and all responses.
