I have an old BFA spec C in my motorhome with about 800 hours on it. The older Onans, 1800 RPM flatheads, are tough to kill. Getting carb parts for them sucks though. Most common problem with them is old gas sitting in the carb and trashing it up.
If it is an older one, it is easy to work on. The heads need to be decarboned every few hundred hours and valve lash set. Brush replacement is a breeze.
Crank it up, use a DVOM or Kill A Watt to ck output (voltage and HZ) loaded and unloaded. If it runs steady under load without hunting around, likely it is good to go.
