Originally Posted by eljefino
Interlocks are best done during new construction. Then if you need to replace your main panel you don't need the PO Co to yank the meter. So little money up front.
Why would doing it during new construction make any difference with changing the panel? The interlock is installed on the cover of the panel and the circuit is installed just like any other. And even if it did make a difference, how often are you replacing your main panel that this would even be a legitimate consideration?
