I have a 7hp HF generator, the advertised output is 3500 watts surge and 3050 nominal. I was exercising it last week with two resistance heaters; one 1600w and one 800w. By my crude reckoning, that's almost 80% load. My questions are:
1.Why did the circuit breaker open after about 30 minutes?
2.Is it just cheap components that are over-rated?
3.Is it reasonable to expect the set to deliver 3050watts for hours on end?
4.Should I replace the breaker with a better part?
5. I need to power two sump pumps, 1/2 and 1/4 in case power goes out in a storm. Do I need a bigger unit?
I don't have natural gas or propane possible. So it's gas or diesel.
Thanks for your help in advance!!!
