The longer, horizontal jack screw, also known as the adjusting screw, was more than half way screwed in, as you can see by the clear marks on the threads. Now, it's not, and that makes me think something might not be right. I realize that the new belt doesn't stretch as much, but there is still quite a bit of difference.
Also, when i was taking off the belt, i took out the long jack screw, but there was still tension on the belt. I had to remove the inner and outer generator to bracket bolt, which allowed the generator to swivel, and removed the belt.
When installing, just tightening the longer jack screw applied tension onto the belt and the generator won't swivel, even though inner and outer generator to bracket bolts were not screwed it.
I would like to know the purposes being served by the screws and bolts.
Old belt:
