854 Million, Hello Car54 LOLHow many millions will they be putting into cam/lifter and pushrod R&D
Because apparently they forgot how to design and manufacture these things
As long as it's reliable i agree too.Give me the hurricane I6 and day of the week over a gas pig v8.
If these are in trucks, then turbos are the wrong direction. We only need to look at Ford and see there are zero turbo options despite them having lots of experience and even one very capable 3.5 turbo on the shelf with similar output numbers; yet they stuff two big block gas options in their work trucks. That's pretty telling.
It depends on what you call cold. Below 0F, it's best to have a circulating block heater that cuts into the heater return hose. Without one, the engine will start, run for a minute then quit when the liquid to gasious converter freezes up.I forget, do those have cold start issues, in cold climates? Regardless, high pressure tanks and limited range are other considerations?
Tangently, the local garage that services busses in our district (might not be the only one, not sure) blew up from one. Link1. Link2. At the very least, my school district might have issues adopting, regardless of reasons for the accident and/or reasons to switch.
As much as I like the power of my EcoBoost, Americans generally have a serious preference in favor of a V8 exhaust note over a V6. In addition, if they get lifters without defective bearings, their V8s are less stressed than a turbo 6, don’t have miles of timing chain, and should generally have better reliability as well.I agree that the ICE age is not over yet despite what the say but I don’t understand the investing back into V8s. Build a turbo six with better fuel economy.
They didn’t learn from the 70’s.
Nope it was smog emissions coupled with gas shortages which killed off the old inefficient iron.Engines were plenty powerful in the 60s, just less efficient. The CRUSHING efficiency requirements killed innovation for power + efficiency and refocused all efforts on simple economic efficiency. That gave birth to pathetic car power from around the early 70s until the late 90s, with rare exceptions and some turbos. Gas became cheap and available by the early 1980s, but the cars were still just pathetic without power.
The innovation we see since around the late 90s has some relationship to fuel economy, but as you point out the microchip had a lot to do with it. Fuel injection as well. Other advances that have nothing to do with raw power, are critical to keeping that power safely on the road - advances in tire technology and materials, ABS, traction control, steering, braking, suspension, etc. Because they could probably do 600+ HP in the eras, theoretically, but it would have been totally impractical and unsafe while also drinking a gallon of fuel every few miles.
It took until probably the first decade of the 2000s to really crack the code on incredible ICE power + efficiency, and fuel has been relatively inexpensive. Compared to inflationary costs, fuel is far cheaper today at $3.50 than it was when I was a teenager at $1, especially considering fuel economy has effectively doubled. Fuel is cheaper and one can drive twice as far on it. A 500hp Mustang is more fuel efficient than a 120hp 1980 Buick Skylark as well.
But was that necessary? IIRC aluminum heads bleed heat faster. Light is good, but you want heat in the chambers, doing the expansion in there.Aluminum heads brought compression back
Every Ford diesel in an HD has had a turbo since 1994.
I would assume this new engine for GM is designed to take on the 7.3.
That is one reason I like a pushrod V8. They don't have yards of multiple timing chains, just one short chain. No chain tensioners, cam phasers, and plastic chain guides to fail. Plus a pushrod engine is much more compact. Compare a GM LS pushrod engine to a Ford Coyote. Those DOHC heads are massive.As much as I like the power of my EcoBoost, Americans generally have a serious preference in favor of a V8 exhaust note over a V6. In addition, if they get lifters without defective bearings, their V8s are less stressed than a turbo 6, don’t have miles of timing chain, and should generally have better reliability as well.
Just bought a slightly used F150 with the EcoBoost. I had three GM trucks in a row with the 5.3. The EcoBoost out performs it in every respect except for highway mpg. There is a 2 mpg hit. I take the F150 over the 5.3 any day.So you want a highly complex twin turbo gas pig with two less cylinders to save 1 to 2 m.p.g
