I have a brand new set of the Falkens just sitting that I haven't installed yet but had purchased them for the other car. My 97 Civic currently has Michelin Defenders but has cracking where the tread meets the sidewall and is a common theme with their tires that were made around 10 yrs ago, luckily Michelin has stopped making this size 185/65/14. I started looking at the Toyo's but the RT45 also comes up. I have a set of Firestone snow tires already mounted that I'm going to swap so I can at least get through the yearly inspection and I won't have to do anything until Spring but either way I will need to purchase a 2nd set of tires. I may end up using the Falkens and then get another set later for the other car.
I had an issue with the brakes on the 97 with the pedal going to the floor so I'm having to drive the 99 that I parked due to the tires and the transmission needing replacement, tires are ok but noisy and wore out, passed inspection last year. I haven't found any leaks but the reservoir was low so wondering if air got into the system when I filled it back up. So far I've replaced the front brakes/rotors but wasn't really wore down at all, mostly just crusty from not driving it. My friend said he'd help me with the rear brakes and bleed out the system, I also purchased new rubber lines for it but hopefully I'll be able to start driving that one again.
Honestly, the Douglas tires are actually pretty good. Only $9 now, might be even cheaper on Black Friday.
Too bad there are no all-weather tires in your size
