Gen 3 Hayabusa rear seat cowl
Canuck - moved to —> California —> Texas —> ???
Wanted to install a rear seat cowl, but I wanted to retain the rear handle so that the bike is easier to put on a rear stand or move around. Normally you need to remove the handle in order to install the cowl.
To retain the handle, the cowl needs to be modified ie. cut into. I did not want to mess up an expensive OEM unit, so I got a cheap Chinese reproduction from Amazon for $70.
It’s cheap, no question about it, but I think it will serve the purpose pretty well. My only gripe is that the silver finish is in gloss instead of mat, like the OEM paint.
You can see the gloss finish vs the mat OEM paint, not a big deal for me.
On the other hand, the red accents match perfectly with the OEM color.
These are the cut outs I had to make for the handle. There is so much that I could do with small and big files to get the contour somewhat match the handle.
How much is the OEM piece? How often will you take off the cowl? I'm one of those super OCD, detail oriented types that I would get the OEM piece and make the modification cuts so everything matches perfectly. Especially if I would be leaving the cowl in place. That mismatched paint alone would drive me nuts 😁.
That mod has been common on 'Busa's since '99. I personally have always removed the grab handle if putting on the solo seat cowl.
If you want to remove the gloss on the aftermarket part, you could wash it with Comet cleanser and a sponge (don't touch the red if you want it to stay as-is) to knock down the gloss. Experiment in a small area before getting carried away.
Good to know, I may tray this first. Thanks for the tip.
They are around $250-300 range on EBay.
It’s super hard to get it perfectly because the bars aren’t square, although they look like they are, plus you need to leave some clearance so that the latch mechanism will work. On top of that, it’s not easy cutting up plastic freehand.
Yes, you can remove the cowl with just the key and put the seat back on.
Nice. I like the idea of this.
I use the handle after every ride to scoot the rear of my bike out of the way in the garage and I occasionally have a passenger.
Could you share a link of the cowl you purchased?
Certainly. Here is the one I got from Amazon. They should have all of the color combos.
But also check out eBay, their prices are a bit better, but in my case, they only had silver cowls without the red accents, so I went with Amazon
Hayabusa cowl from Amazon
