At our winery we have a Westfalia Separator, made in Germany. We have changed the gear oil in the unit before, but I don't think the "Pitt Penn" 80-90 is really a good choice.
Here are the specs from the manual on what it needs:
C-LP 114 (according to DIN 51502)
BTW they recommended "Serarator lubriciating oil C-LP 114" on the page.
VISCOSITY:
Meets the following: 114 +/- 8cSt at 50 deg C, (220 +/- 22 cSt at 40 deg C)
ADDITIVES:
a. Additives giving increased protection agasint corrosion and increased resistance to again, with properties preveing corrosion on steel according to DIN 51355/B
b. Additives for decreasing wear and increasing the load-carrying capacity. The "FZG" gear rig test according to DIN 51354 as well as the test according ot A/16,6/90, load grade > 12, must have passed.
c. Demulsifiying behavior according to DIN 51599 < 60 minutes.
These are strange paramaters. I tried to get some information from Amsoil tech support but they were not very helpful. I thought surely some of the Amsoil products might be in this league but now, I'm not sure.
I'm pretty sure that the local Pitt-Penn 80W-90 grease at the local hardware for cheap, cheap.. is not what we are needing.
Thanks!!
Vern
VISCOSITY:
ADDITIVES:
Thanks!!
Vern
