I know some people have been curious as to what the Torco does in a sample so I did it with my first GC run. I only used half of the bottle (~6oz.) in this sample. Driving habits have changed considerably with this sample as well. Instead of the 300 miles a week (freeway) I was doing, I am now doing 50-70 miles a week. The sample with in use from late March until mid November, it was able to see the cool spring/fall and the hot desert heat.
Blackstone was the lab of choice.
Jon: Thanks for the note about the friction reducer. We are guessing that is where the extra silicone is coming from in your oil (found, read below). We doubt its abrasive dirt escaping the air filter because wear still looks ok and shows no changes that would indicate poorly wearing (or abraded) parts. The TBN was 0.5 showing little active additive remaining in this oil. We did find some fuel dilution which is common in engines that see a lot of city driving and/or idiling. About 2.0% is the most we like to see so well keep an eye on it in the next sample.
__GC___RP___M1____Oil
Ford___M1_Fram____Filter
6620_5.6K___3K____Mileage
___4____3____5____Aluminum
___1____1____1____Chromium
__31___31___21____Iron
___9____6____4____Copper
___0____1____1____Lead
___1____1____1____Tin
_337___91___52____Moly
___0____1____1____Nickel
__11____2____7____Manganese
___0____0____0____Silver
___0____0____0____Titanium
__17____0____1____Potassium
__13____6__122____Boron
__32___37___61____Silicon
___6____6____6____Sodium
3436_1915_2817____Calcium
_108____6___13____Magnesium
1836__615__604____Phosphorus
1111__680__808____Zinc
___0____0____0____Barium
_0.5__1.5____5____TBN
63.2_57.7___61____SUS @ 210
_340__380__390____Flashpoint
_2.3__0.5__0.5____% Fuel
___0____0____0____Antifreeze
___0____0____0____Water
__.5___.4___.4____% Insolubles
I guess my lunch breaks in the car listening to the radio are needing to come to an end if I want my fuel dilution to stop. Am I correct in assuming this is why my copper wear is up? The moly wasnt as high as I was thinking it would be with what the specs on the Torco were showing. The silicon should be considerably lower in the next sample. The car went down for trans replacement when this sample was pulled. I dropped the oil pan/pump/pickup to replace the front main seal. When I looked in the pickup it was full of some of the silicon that apparently escaped the gasket when I did the oil pan gasket last year. Cleaned out the pickup and pan so all should be good next time. The Baldwin B2-HPG should help at capturing any stray pieces that were too small for me to see.
In all, I believe I should be happy for this result on what is now a 137,000 mile engine.
-Jon Miconi
EDIT: Spelling
-Jon Miconi
EDIT: Spelling
