Gave up on quadrajet electric choke today...
Originally Posted by FlyNavyP3
Originally Posted by Jmoney7269
Every engine I have ever built or helped friends upgrade we have put Holley 650 double pumpers on them and removed the manual choke. A properly tuned and matched carburetor to the engine shouldnt need any choke. Literally give it 2 little pumps and turn the key and it fires off in 2-5 seconds. The square bore holley carburetor is the best upgrade anyone can do for a engine. There is a reason why people who have had quadrajets then upgrade to double pumpers call them "quadrajunks".
My 434 has a 950 double pumper from pro systems with a 4 corner idle system and I have never heard of people adjusting air fuel mixture screws with a vacuum guage..... all air fuel adjustments should be made by "tuning by ear". Same thing we do for small engines that run phenomenal when I get done with them.
Quite a bit of misinformation here. Engines tuned currently do need a choke to assist with cold startup. Big difference between a street strip or race setup and a carb on a RV or truck.
The Q-jet is one of the very best carbs at accurately metering fuel across a wide RPM and load scale, it has WAY more fine adjustments available than a standard Holley carb, metering rods for extremely fine fuel control, lean cruise adjustments, in a word it's excellent.
So let's get this straight, since you've never heard of tuning idle mixture with a vacuum gauge, it's wrong, but doing it "by ear " is correct? Using vacuum is a perfectly acceptable way to tune idle mixture.
A well tuned Q-jet can out perform a Holley on a street driven vehicle in numerous ways, part throttle precise metering, outstanding throttle response due to the small primary bores, lean cruise adjustments for cruise mileage, increased load enrichment sensitivity over the Holley which just uses a fixed enrichment where the Q-jet is a curve as the metering rods withdraw, air door secondary on the Q-jet prevents lean bog when transitioning from primary to secondary circuits.
I'm not bashing the Holley here, I own multiple, but it's not fair nor is it accurate to say as a blanket statement that the Holley is ALWAYS an improvement over the Q-jet because it's just flat not true, they each have their place.
Misinformation? Lmao gimme a break.....
A holley 650 double pumper can do anything that a quadrajet can do, but better. The only reason in my eyes to put a vacum guage on a carburetor is if you're synchronizing two of them. In a majority of cases, a quadrajet is too lean, and therefore that is the reason it's so hard to start up and gets a smidge better fuel mileage. Modern carburetors can be purchased with all the customization that we used to have to send off and get done. A properly tuned 650 double pumper that has the right power valves, air bleeds adjusted, accelarator pumps adjusted, air fuel screws TUNED BY EAR If you know what you're doing, the carburetor wont need any choke! The first 350 I ever built we sent the carburetor off the CHUCK NUYTTEN and everything was matched to this engine and it's intended purpose, and not once did it ever need a choke from temperature ranges 20-110...... same old song and dance with any engine I have ever built or help a friend upgrade....... two small pumps, spin it over for 2-3 seconds and it fires off. And they/I dont have to sit for 15 minutes with the stupid thing on choke or even deal with the possibility of a choke failure. The reason most machines now days need chokes or enrichment circuits is because they don't have accelerator pumps to prime them for starting.
There was a comment made also about how most all that can do the miracle work on these carburetors have long since retired. There are still a few of us out there yet. I'm only 36 so lots years left yet...... and yes I would run a 650 double pumper holley any day on a rv or whatever else has a 350 to 454 engine.
P.S. tuning idlewith a vacum guage doesnt do a bit of good besides show how much vacum its pulling..... any mechanic worth his salt knows the only way to tune a idle air fuel mixture with a carburetor is by tuning it by ear, or using a stand alone oxygen sensor. In my experience, the only time I have ever needed to use a vacum guage was to calibrate throttle sensors to factory specs so that the ECU and fuel mapping was all on the same curve.....
I was a quadrajet guru 20 years ago. They are the finest carb money can buy, and there is no way on earth I would replace a good running quadrajet for a Holley on a daily driver or cruising car. Race car has different demands.
You really wanna get some BUUUHWAAAAAA , slap one of these on there. I have one and my uncle has 3 of them.... will be worth some huge money one day. Got them at a swap meet and did full rebuild kits on them and added a adjustable diaphragm.
[Linked Image]
Q-Jets get tossed mostly due to nobody being around who can properly diagnose or tune them, or the carb just being worn out, combined with the former.
We've ditched a lot of them for the Marine Holley spreadbore. We used to send the Q-Jets out to be rebuilt, but they always seem to come back just as bad or worse. Got tired of the same old bull.
Unless you are a purist and have to worry about judging, an Edelbrock 1406 electric choke carb is the way to go. Installed many on GM OEM Q-jets................ they solved all the inherent problems. That + a Performer manifold is even better.
Ah, the QuadraJunk debate goes on...
Q-Jet is a great carb; by far the best carb ever designed for a production car.
They have been used on everything from 6 cylinders to 454 V8's via specific configuration.
There are many problems with them nowadays, none of which are due to the carb.
Commercial rebuilds almost always ruin the carbs because they do a generic rebuild.
There are 3 good rebuilders that I know of: Cliff Ruggles, Lars Grimsrud and Henry Olsen.
Also, there are very few cores left.
The 1406 is a copy of the old Carter AFB which predates the QJ by years. A simple carb; easy to tune and pretty inexpensive.
There are so many Holleys. The high HP cars in the late 60's and 70's used Holleys primarily due to marketing.
They do make a decent Q-Jet spread bore replacement.
I have a wonderful QuadraJet on my 1968 L36 Corvette Roadster; built to perfection by Lars.
He is a stand up guy and a tribute to the car hobby.
I think I discovered that I have another issue.
I think my vacuum advance is torn.
I unhooked the VA on my c10, and started it, it ran really rough, and when I put it back on the RPM screamed back up to the fast idle.
The RV hardly changes. It raises rpm, but not like the daily driver C10
For $7 I bought a new one just to take the possibility of it being the original one from 83 out of the equation.
I enjoy the carb discussion - it's a fading art. In my limited experience, both QJ and Holley were excellent, but they both had unique advantages. It was easier to get a Holley bolted on, set right and down the road. They were simpler and in many hands more reliable. If you got it set close, it was good and you didn't have to mess with it. The QJ was a different animal - for most of us they were harder to figure out and therefore got a bad rap. But if it was set up properly, you could get the same power and better MPG and was reliable until a rebuild was needed.
