Gatorback Belts
Wisconsin
My '93 Nissan Maxima has had belt squeal as long as I have owned it. Nothing seems out of line and new belts only seem to help for a short time. The poly-v power steering belt seems to be the culprit. It will be glazed and cracked long before the others. It is the only one that has a back-side tensioner pulley.
Earlier in the week I replaced all 3 belts with Gatorback belts from Autozone. The ribs are made in 3/8" sections. The belts are quieter than I have ever experienced. I don't know how long it will last.
Anybody have experience with Gatorbacks?
yes. with a v6 caravan with a missing splash shield. the previous belt would slip and jump off if a puddle was hit right. the new belt was a typical sepentine with the grooves sideways in the belt. belt alignment was right on and the tensioner was good but would dump the belt if a little water was splashed up. the gatorback belt worked well and it never occured again. i later found out that this was a pretty common deal with those vans. they are a nice quality belt a little pricey though but worth the money in mho.
The gaterback seem to be very quiet and well worth it, prices are now usually comparable to other brands.
-T
I put a Gatorback on our van and haven't had any problems. I bought mine at Autozone and it was actually within a $1 of the Gates brand.
Gatorbacks are the only belts I will use on my LS1. My only problem with them is availability.
Gatorback belts are very popular with the Crown Vic, Grand Marquis, and Lincoln Town Car crowd. Belt squeal is an occasional issue at wide open throttle shifts on these cars.
I have used Gatorbacks and Gates belts on all of my cars. The Gatorbacks are very high quality belts indeed and they should serve you well.
I'm happy to hear about the positive experiences. I am getting readyto replace the V-belt in my Toyota and bought a Gatorback. If this thread is still active when I do it, I'll post with the results.
I wouldn't recommend one for anyone with a GM 3800 V6. On my car at least, this belt caused a wierd whistling noise from the alternator pulley. A Dayco belt fixed the problem.
I use gates belts only (or OEM Japanese such as Mitsuboshi, Sumitomo, etc.) I'd stay away from belts suchas Dayco and to some extent, GY gatorbacks for they tend to squeal...
The Gatorback belts for my wife's GTP were a pain to put on, especially the blower belt! Good Lord they fit tight.
They seem to perform well, but next time I'm going to Gates or Dayco.
