Garage lighting
When I bought my house, the area I designated as a workshop in the basement was lit with a single 60 watt bulb. Completely useless.
I used two LED fixtures from HF. Absolutely perfect. Now that my youngest is in his senior year of college, I'm finally building the 24x36 garage I've wanted for years. I plan on using the same lights.
I have three 8' x 2 bulb fluorescent lights. Bought LED bulbs where I could gut the fixture of ballast and rewire the inside of the fixture for the LED bulbs.
I figured with new fixtures I might need to move wiring in the ceiling and did not want to get into that.
Go 28’ deep. It’s a huge difference in the move around/bench area.
Do you have access above the ceiling?
My 2-car came with the standard 2 single [bare] bulbs... I languished for hours looking at awesome solutions, but a year later had done nothing. I do have access above. So to just get something done, I measured out a 3x3 square and surface mounted 9 shallow 11-b boxes. Climbed up into the attic and ran 14-2 between the 9 boxes (Eliminating) the 2 original hanging bulbs lights. Wired up and mounted the standard 4k "puck" lights from Amazon.
Is it perfect / 100% ideal for everything? No. but for ~$250 it is excellent and 10x better than the builder [minimum code] and looks pretty slick. (Price of wire is a shocker! ~$1/ft 😲 That was ~1/2 the total project cost) FWIW, my last house I connected a bunch of Horror Freight LED shop lights... Got the job done, but was a bit jankey... This way better for a minimum amount more.
