Gaping tool-one for every type of gap
Long Island/New York
Is there a gap tool that could be used for every type of spark plug gap needed?Some spark plugs require a gap of .036 but not all feature this type of gap.Do you need to buy several gap tools as needed?Thanks Joe
Originally Posted By: Trav
http://www.amazon.com/Powerbuilt-648394-...ds=Feeler+Gauge
Wow...I've owned that EXACT gauge for about a million years...I guess they don't feel the need to update it much.
I thought plugs came pre-gapped these days? And that it was bad for the plug to bend them? The expensive plugs made of exotic materials meant to 100k+ that is.
I have this type. Both of the Snap-On's and one Cornwell:
http://www.collectingsnapon.com/index.php?page=pliers/SparkPlugGapping
You're supposed to use a wire type gauge to measure/set plug gaps but I've been using these plier type gap tools with blades for 4 decades without issue.
If you go with the plier type tool, avoid this type with the round disc:
http://www.jegs.com/i/Accel/110/380700/1...CFQZcfgod-IIAKA
I've found that in use, the anvil on top of the disc covers up the gap markings. I always felt the need to dig out my wire gages to confirm the gap. I tossed these in the trash after a few uses.
Wire is fine and recommended for non exotic material plugs, for platinum and iridiums you want to use a feeler and use the bending tool on the Ground electrode on all types.
Never try gapping surface or multi electrode plugs like Bosch +4.
