My high boost Turbo S2000 NEEDS high octane fuel. At the local pumps, 93 octane is dispensed from a "blending pump". Since most people purchase 87 octane, there is, I'm guessing, about a gallon of regular gas in the line/filter and pump. Possibly more than a gallon!
Problem is, my tank is just over 10 gallons capacity. So, I end up putting 8 gallons in. (this is due to modifications, nominal capacity is 13)
I bring a 1 gallon gas can and fill that first. I no longer see the gas change color at the 1 gallon mark. AND, I'm sure each gas station has a different setup.
So, I'm stepping up to a white, 2.5 gallon "race gas" can, so I can more clearly determine how much regular I'm getting.
I know the .gov says you must purchase 3 to 4 gallons to be "sure" the fuel in your tank is the rated octane. That tells me nothing and does not help me determine how much regular I'm getting.
