gathermewool
Site Donor 2025
'08 Civic
71kmi
Very gently driven with a lot of highway.
With the MM indicating 15% @ 6,188 miles on the oil change, I'm trying to decide which to do:
1. Change the oil at 0%; leave Fram Extended Guard filter on for on for another oil change interval.
2. Reset the MM and change it when the MM next indicates 15%; change filter at this time.
3. [You suggestion here]
I did finally get my GET rebate check, so the oil change only cost me $4.80 ($26 - $20 rebate check, multiplied by 4qts/5qt jug,) but it would bother me changing out such expensive (and seemingly high quality) oil out at such a short interval -- extrapolating out, the MM should indicate 0% at ~ 7200 miles.
FWIW, the next oil change will be a mix of the following leftovers:
1. 1 qt G-oil 5
2. 1 qt Edge
3. Remainder -- Valvoline Maxlife 5W-20 (probably less than 4 qts, due to leaving the filter on.)
71kmi
1. 1 qt G-oil 5
2. 1 qt Edge
