Funny story - Socket 1150 board
OVERKILL
$100 Site Donor 2021
Ontario, Canada
So I'm re-boarding a Gateway AIW PC for a client. I've done about five of these so far, they are AMD-based and the storage controller on the board [censored] the bed and renders the board useless. Boards are made by Gigabyte IIRC, they have a darker aqua PCB and a funky form-factor.
I've swapped in ASUS boards with the first few being 1155's back when that socket was common and the more recent ones have been 1150's including this latest. A Micro-ATX board, while not the "proper" form factor for the chassis (the OE board has a backwards orientation) is able to be fitted if you get creative with HDD placement. Topped with whatever i3 is the best deal in my price list and recycling the DDR3 from the OE board.
This time around, used an ASUS H81M-A topped with an i3-4160.
Get it all together, makes all the proper post sounds. No video. Do a bit of troubleshooting, jerry rig in a PCI-E vid card, try some different RAM...etc. Nothing.
Check ASUS's CPU compatibility list (which gives required BIOS revision) and then check the board. BIOS is too old for the CPU. ARG!
Out comes Google to see if there's a workaround.
Find a post on a forum with the same issue, same board family, same generation CPU. Confirmed, no video. Posts fine with a Celeron G1820. A rep from ASUS replied in the thread, stating that it needs to be booted with an older CPU to update the BIOS and IME firmware. Ridiculous!
Great. Wholesaler has no older CPU's. Could RMA the board and try to get one with a newer BIOS but that's time consuming.
Checked Kijiji, found a Celeron G1820 for $50.00. Should be here by Wednesday.
I've had to do this a number of times in the past, but I usually have enough older CPU's in stock that I don't need to order/buy anything (and no IME firmware is involved). Not this time
Originally Posted By: 901Memphis
Yeah, it's time to update your stock of older processors! Some good deals on ebay i have seen lately.
I was just looking at what it would cost to upgrade the Core2Duo E8200 (775 socket) in my old Dell desktop. Looks like Core2Quad q9550 can be had for about $65 on ebay. Not sure if it'd work though and if I could reuse my existing CPU fan.
no no no... get the pentium anniversary edition and mobo 99$ at microcenter
Best value upgrade ever... then sell the old ram and buy new.
DDR2 is actually somewhat pricy.
Pentium G3258
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Pentium+G3258+%40+3.20GHz
I had that issue a few years back with an abit board(storage controller going belly up), the replacement board was gigabyte and had a defective clock generator (would run at 2/3rd speed)
The replacement for that replacement was DOA, the asus board I replaced that one with wouldn't wake my hitachi deathstars from sleep(causing bluescreens)
That was the computer rebuild from um. "Down Below"
Computers are so much more reliable now.
Thanks, but that pentium CPU is "in store only" and there are no microcenter stores near me. Besides, I would also need a new power supply at that point.
I was just thinking out loud. Not gonna put any more money into this thing. It is sitting in storage anyway.
I have a C2D E8500 in my desktop, killer overclocker, easy 4Ghz+ with a halfway decent hsf. Don't know if the E8200 is like that too but it's fun to turn them up and see what happens.
Unfortunately there is no overclocking with Dell BIOS.
I guess you couldn't turn off the on-board disk controller in the original Gateway and install a card that once could boot from?
Nooooo, this is an AIO PC, it has zero internal space.
I don't play in the PC world much. What I work on is either 1U, 2U or covers 6 floor tiles in a DC. Not much in between.
