Fuel sender identification - ohms
Bolivia
Does anyone recognize this Toyota (I think) fuel pump and sender unit? I need to know what the sender ohms are (or how to test and find out)?
I have put it in my Mini, and need to match the ohms with the gauge.
Probe between the rheostat (looks like the red wire) and ground. Run the float through its range, the ohm meter should move around with the float. A quick google shows should be something like 10-110 ohms.
Unfortunately I did not think of this before installing the tank. Picture was before. I have to drop the tank to pull the sender. Or assume the gallons or so I put in yesterday when I ran out is "empty" and add til full.
From what you say and I've seen on Toyota sites, if I can modify the resistance to 240 empty and 30 full, it will read backwards. Which is still better than what I have.
  • Wow
Reactions: D60
