Bird Horse
- Joined
- Mar 23, 2025
- Messages
- 32
Hello! I just need some advice. I am trying to diagnose a misfire on my '13 Optima 2.4L. Timing is good, tried swapping the coils to no avail. Now I am on to checking the fuel pressure. So, a couple of things. One chapter of the book says pressure from the low pressure line should be 338-348kPa at idle, another chapter says 495-520kPa. The gauge bounces quite a bit, which I assume is due to the action of the HPFP, but tops out at exactly 520, so I suppose that is good, right?
But, I also test fuel pressure drop after shutoff. Seems to loose about 8lbs in 5 min (sorry for using different scales here). Is that too much? And do you guys think that could be the source of my problem? It is just a P0302 (cyl 2 mis), She stumbles just a little and leaves a bit of soot out the back, but drives fine and no pinging, knocking, or backfiring.
This is my first time working on a GDi engine so I really appreciate the help.
