I have a small block 350 in my car. Based on casting #'s (3970010) and engine code (V0806TXB) the block is from 1975. The cylinder heads (333882) are 1.94 intake, 1.5 exhaust and match the block. I know that GM started making hardened valve seats for unleaded fuel in 1971 but the guy who built my engine had used CD-2 lead additive in the car before I got it. I have continued to use it but as I to do more research I do not think I need it. I don't know my compression ratio but I do not believe it is over 9.0:1. All that said, what are thoughts on running the lead additive? If I don't need it for the valve protection should I use it to boost my octane? If not should I start running 91 octane gas without the lead additive?
