can a fuel injector get "stuck" in a position where it would cause the engine to rev high at startup and then settle down to normal rpm? my 92 ranger does this on startup. i replaced the throttle position sensor, air idle control vavle, cold air temp sensor, fuel cap. the engine shows no trouble codes. took it to the dealer. nothing out of the ordinary. they even kept it overnight so they could have the code scanner in place at start-up. it revs to about 2,300 rpm when first started in the morning and then settles down to its normal 800 rpm idle. after the engine is warm, it doesn't do it. then, the next morn..boom, it does it again. it seemed to have happened shortly after using the chevron fuel injector and intake valve cleaner. the ford dealership mechanic told me to "just drive it". yeah right.
