Fuel Additive, which one?
North Carolina
I maintain (own, but not drive) three vehicles, a 2004 Honda Accord, a 2008 GMC Acadia and a 2008 Toyota Avalon. I’ve used Lubrication Engineers LX-2300 with good results, increased gas mileage, better used oil analysis, and a general “good feeling”; I am currently experimenting with Schaeffer’s Soy Ultra with no increased gas mileage, and no “good feeling.” The Schaeffer’s came with one of the bottles leaking and the packaging really looks cheap. I have a case of Red Line SI-1 that I haven’t used enough to comment on. I’m not very interested in Marvel Mystery oil as I used it in lawn mowers and mini bikes as a kid. Does anyone here use Red Line on a regular basis?
If everything is up to snuff with an engine, there is not much that can be added to the fuel to increase mileage, except maybe E0 gas.
So what is wrong with each vehicle? I would use a PEA based additive like Techron are per directions for maint.
I use FP+ from Lube Control regularly and haven't had a fuel related problem in ten years, two cars and 400k miles.
That new BG44 seems excellent.
But those strong aftermarket PEA cleaners are for once or twice a year, not every tank.
BTW -good gasoline HAS PEA in it - just a small amount.
What do you want to do/accomplish?
For lubing the fuel pump to prevent wear, and as a top end lube, TCW3 2 stroke oil can't be beat. For some cleaning and some lubing, MMO is also cheap and beneficial.
Originally Posted By: boxcartommie22
mechtech,is the red line 2 stroke as good as tcw3 2 stroke oil?
The RL "Watercraft Injection Oil" IS a TCW-3 rated 2 stroke oil. (But, like everything else RL, it IS pricey.
daily d fortunately has done his homework. So the RL IS aTCW3 type.
That means water cooled 2 stroke oil. It burns cleaner, and has less octane reduction that air cooled 2 stroke oil.
I just added 3 ounces of ST TC-W3 to my 12.5 gallon tank when I was down to a little over a gallon left, then drove about 4 miles to a gas station and filled up. So I am probably at about 500:1 ratio. After 30 miles of driving around there is actually already an idle difference at traffic lights. I know for sure by watching the edge of my hood which is no longer vibrating.
