- Joined
- Nov 29, 2009
- Messages
- 10,258
I've been noticing on slow tight turns that occassionaly the front tires will slip and the truck rocks back and forth slightly when turning. Almost like the tires are slipping on bananas peels. I know the last time my truck was in the shop they said one ball joint and one tie rod had some play. I guess a loose tie rod would cause this? It's mainly only on tight left turns which I don't make as often.
