Many medium and large fleets are ditching 15W-40 heavy duty engine oil
(HDEO) for 10W-30 HDEOs. According to a recent study about 20% of medium
and large fleets are now using 10W-30 HDEO (Power Systems Research, 2014).
The most common reason for the change is the increase in fuel economy by
switching to lower viscosity oil.
1. FUEL ECONOMY IMPROVEMENTS ARE CORRELATED WITH VISCOSITY
Engine oil’s main job is to protect your trucks’ engines. The combustion cycle
creates heat, soot, and acid; all of which the HDEO must mitigate. However,
HDEO also presents the problem that it adds drag to the engines’ movements.
Imagine swimming in honey; it would require a lot of energy to get across the
pool and stay afloat. Swimming through honey is much like what your engine’s
moving parts have to do to move through oil. As you can imagine, the thicker
the oil, the more energy it takes for the engine’s parts to move through it. There
is nothing magic that makes a 10W-30 HDEO more fuel efficient; it is simply
thinner and therefore produces less drag on your engine.
2. DON’T SACRIFICE WEAR PROTECTION FOR FUEL ECONOMY
While the viscosity of an HDEO accounts for its contribution to fuel economy,
it is the composition of the base oil and additives that protect your engine from
wear, soot, and acid. Because 10W-30 is thinner than 15W-40 oil, its film
strength can be weaker and it can be more prone to oxidation. Therefore, high
quality additives are needed to compensate for those weaknesses in order for a
10W-30 engine oil to protect as well and last as long as a 15W-40. High quality
10W-30 oils can perform as well, and better than industry-standard 15W-40 oils.
3. NOT ALL 10W-30 ENGINE OIL IS THE SAME VISCOSITY
The stated viscosity of a HDEO does not represent an exact viscosity, but rather
a viscosity within a range on the SAE viscosity scale. Engine Oil viscosity is measured
in centistokes (cST) at 100°C. “W’ grades are measured at 40°C. 10W-30 engine
oils can fit anywhere in the range of 9.30cST to 12.49cST. Engine oils closer to
9.30cST will provide better fuel economy benefits than oils closer to 12.49cST.
Therefore you could have two separate 10W-30 engine oils produce two different
results in fuel economy. Furthermore, if you are comparing the fuel economy benefits
of a 10W-30 to 15W-40, your results will vary depending on the exact viscosity
of the 15W-40 oil, because the 15W-40 designation represents a range of viscosities.
4. BETTER FUEL ECONOMY DOESN’T NECESSARILY MEAN
YOU’LL BUY LESS FUEL
While this may sound straightforward, many fleets are disappointed when they
switch to 10W-30 HDEO and don’t see a reduction in their fuel purchases. All
things being equal using 10W-30 HDEO requires less fuel than using 15W-40
HDEO. However, all things aren’t equal. Fuel prices fluctuate, routes change,
cargo weights differ, weather never stays steady, and drivers’ behaviors can vary.
The best way to ensure your trucks are getting better fuel economy with 10W-30
HDEO is to develop and maintain a precise method for calculating fuel efficiency.
Don’t just look at your fuel bills to evaluate the fuel economy benefits of switching
to 10W-30 engine oil. One way is to use data from the electronic control module
(ECM) to statistically isolate certain variables and calculate differences in fuel
economy from before and after switching to 10W-30 engine oil and to compare
different trucks. The bottom line is that 10W-30 HDEO produces less drag than
15W-40 HDEO, but sometimes it takes looking below the surface of a fuel invoice
to notice the changes.
5. LOWER VISCOSITY HDEO WILL BECOME THE NEW NORM
New governmental standards for greenhouse gas (GHG) emissions and fuel
economy are adding pressure to engine manufacturers to produce more efficient
engines. Additionally truck, engine, lubricant, and fuel manufacturers are
continuously looking to add value for their customers; one way is to make a
product which allows your customers to use less fuel. Currently a new category
of engine oil is being developed and evaluated by the American Petroleum
Institute (API) in conjunction with the new heavy duty emission standards set by
the EPA that will go into effect 2016. The new engine oils haven’t been given
a specific designation yet (like “CJ-4”), but have been dubbed PC-11 (proposed
category 11). The details of PC-11 haven’t been worked out yet, but industry
changes are forecasting that the majority of heavy duty engine oil will shift from
15W-40 oil to XW-30 (i.e. 0W-30, 5W-30, and or 10W-30). The good news
is that you don’t have to wait for the entire industry to shift to 10W-30 engine oils
to start seeing the fuel economy benefits of 10W-30. Contact your Shell Lubricants
rep today to learn more about taking the plunge to fuel savings.
FOR MORE INFORMATION, CONTACT US
Shell Lubricants’ Technical Information Center: 800.237-8645
[email protected] shell
