First, I'd like to thank all that helped me with your wisdom and advice. Second, thank you Bob, for hosting a web site that allowed me to do the bulk of my bypass filter research.
Well, I installed a Frantz in my 1966 VW hot rod. I plumbed the inlet from the oil pressure T-fitting.
The return line was plumbed through the fuel pump block-off plate.
And hung the unit on a cross-bar that holds the rear bodywork together.
I'm pretty happy with the results.
I'm using a Frantz 1.6" adapter and Scott 1000 rolls.
By the way, I wanted to add, that I got a cr*pload of venom and name calling when I posted this on my favorite VW forum. People love to make assumptions without doing a minute's worth a research on the subject. People freak out when you say you are filtering oil through toilet paper. Now, I'm sure it would have been different if I had described it something like "Tightly woven paper-based high-density filtration media."
Brian
Brian
